Tiara Open 2006 36' Open
Looking to replace light bulb for ACR bow spot light, JCD12V55WDX.  The prices I'm seeing are upwards of $65.00 any aftermarket out there?
The finish on the spot light is pealing anyone have any success in repainting ?
Third question anyone know where to get white plastic screw cap covers for the hardtop ?
I can help you with two of your questions: I painted my ACR housing using Awlgrip. Cleaned it real good, scuffed it up, sanded down blisters and peels and hit it with a few coats. Looks brand new. You can use the color card to match your gel or find a awl mix dealer that can custom mix the topcoat. I think Tiara uses Fresh White. You can check with them to be sure. I actually used Stark White which is a standard color and it matched the gel coat perfectly.
You can get your snap caps here. Have to buy a bag of them but they are nice to have around.
(05-22-2018, 09:19 PM)jclark003 Wrote: [Only registered and activated users can see links Click here to register]
Thanks appreciate the help do you know the size snap cap
you can get them on amazon.... just got one myself.... also check eBay.  didn't find aftermarket....
i am considering going to the LED ACR light..... its awesome.
Capt Brett
(05-22-2018, 09:16 AM)firstlight Wrote: Looking to replace light bulb for ACR bow spot light, JCD12V55WDX.  The prices I'm seeing are upwards of $65.00 any aftermarket out there?
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
Yes Amazon is a good place too. Pretty sure they are 5/8 with a #10 hole. Might be worth it to take one down and measure diameter.
True value hardware has the screw caps. Just replaced all of mine. Home Depot or Lowe’s should have them too. Lastly check amazon.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 2 161 10-05-2026, 11:57 AM
  38 open bathroom recessed light bulb twilson0929 3 524 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 411 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 807 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,439 05-22-2026, 06:41 PM
2006 36' Open00
