Tiara Open Tiara 31 open crusaders getting when WOT
I have 31' Tiara 1999 with 454xli crusader engines . Port engine i keep getting hot while cruising at 3000 rpm . But not at the dock . Only when WOT . New risers in 2015, new pump last year , brand new impeller , 2018 new oil cooler . She runs perfectly fine even higher rpm at the dock with out getting hot . Only in gear at higher rpm 3000k she is getting hot, getting trans temp alarms and engine as well . Any advise to where to look at this problem would be great.
Thank You
Al Frown
Obstruction in the oil / transmission cooler would be the first place I would look.
I reread your post and see you already replaced the oil cooler. Time to invest in a heat gun and see where the hot spots are.
Have you had the heat exchanger cleaned?
Thank you i am going to back wash them see anything made in there . Cooler was replaced last year .
(08-14-2019, 06:53 PM)Misdirection Wrote: I reread your post and see you already replaced the oil cooler.  Time to invest in a heat gun and see where the hot spots are.
some many choices with that heat gun any brand you suggest ??
Had this start at end of last season.
Cleaned coolers - no change.
When I went to change impellers - found water pump bearings bad.
Replaced pump
All good
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 3 813 06-02-2026, 01:58 PM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 1,326 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Repowering a 1992 3300 Open WOLFDAWG71 1 1,026 02-17-2026, 06:46 AM
  [Tiara Open] 2900 open - 454 mounts North000 0 526 06-12-2025, 08:21 PM
Last Post: North000
  [Tiara Open] Repowering a Tiara 3100 Open with 2 outboards drake 2 3,257 08-21-2024, 09:09 AM
Tiara 31 open crusaders getting when WOT00
