Threads: 45
2
Home Port: Long Island Sound
I had to pull my freshwater washdown to run some wire. The freshwater washdown broke getting it out. Amy idea where I can order a new one?
Threads: 6
1
Home Port: North East
Vessel Info: 2005 4400 Sovran
Cummins QSM-11 660HP
Hi,
Are you talking about the female 'push lock' hose adapter?
Ken
Threads: 45
2
Yes but I need the entire module. I had to remove the whole piece to run some wire and whatever sealant used to install it was very strong I ended up breaking two corners off. There are four screws, one in each corner, and it is located just below the main A/C breakers in the cockpit on the starboard side.
Threads: 45
2
That is the box. Mine is banged up pretty bad. Looks like I might have to fabricate something. I found a round recessed fitting. I think a piece of starboard with the single round fitting in the center might do the trick if I cannot find anything else. Spent a good hour searching the web for something I can use.
Threads: 6
1
If i remember, mine had the actual Tiara part number written in Magic Marker on the back side of it. I called Tiara and it was still available, but on the pricey side. Tiara CS can always look up parts if you give them the HIN. Hope the season warms up soon! We are out on the North Fork, Where do you keep your boat?
Ken
Threads: 45
2
I am right across the pond from you in CT. I will try Tiara. I have contacted them before with success. Lets hope this is the last crappy weekend, it has to warm up eventually.
