Threads: 94
1
Home Port: ludington michigan
Vessel Info: 2003 4200 open qsm 11 660hp
on the fridge in back of the helm, whenever i hit a big wave it pops open and cans come flying out, any suggestions on how to fix this? maybee put a clip on the bootm of fridge to go along with the one on the top?
Threads: 6
1
Home Port: North East
Vessel Info: 2005 4400 Sovran
Cummins QSM-11 660HP
i added a second 'spade' clip on the top of the door next to the existing one, seems to do the trick.
Threads: 94
1
what do you mean spade clip? i was gonna put a clip on the bottom of fridge to match the one on the top of the fridge?? im just nervous about drilling a couple holes in the fridge??
Threads: 6
1
Hi,
This is what we added except in plastic:
Sugatsune 1-15/16" x 3/8" Ball Tension Catch
Model: BCT-50
What model fridge? Maybe check with manuf of unit to see if they have a part/latch etc that doesn't require drilling. I admit i wasn't crazy about drilling it either.
Threads: 8
10
Home Port: Port Canaveral, FL
3406E Cats
Its OK to drill around the door of your fridge. The only thing in there is foam. All the electrical is in the bottom and the cold plates are visible in the fridge itself. Most everything runs up the rear of the unit.
Threads: 94
1
awesome, thank you guys, very much appreciated...
