Engine warning light blinks
I have 2013 6.0l Crusaders Captains choice in my Tiara 3100 Coronet.  While trying the engine sync mode for the first time the other day I brought both motors up to WOT after a few seconds the starboard check engine light appeared and I immediately shut the motors down.  After checking all the fluids and visual inspection of the motors, I restarted them both.  The starboard check engine light blinks once every 5 seconds and after I start the motor light goes away and motor runs perfect.  No issues or blinking MIL lights on the port motor.
Any ideas of what a single flash code may be, I have a service tech schedule, but it will take 2 weeks.
Thanks?
I didn't know that the dash lights indicate any particular flash code.
I was under the impression that if you had an engine fault and don't have a scan tool, you can hook an LED light to the data connector on the engine to get a particular flash code.
-M1
Sounds similar to what I have read, appreciate your input. I just ordered a Rinda techmate pro hand held unit. Thanks ?
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 3 825 06-02-2026, 01:58 PM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 1,335 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  Engine shut off while running Mydiamond 1 804 08-10-2025, 07:51 PM
  31 Coronet "red" check engine light rickturner 0 833 07-30-2024, 07:16 AM
Last Post: rickturner
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,548 10-18-2023, 04:32 AM
Last Post: czarcone
Engine warning light blinks00
