Dometic A/C pull out.
I'm pulling out my Dometic Marine AIRRRR, Vector Compact. I have the water and drain hoses off and unbolted from the floor. The electric box access is giving me trouble. I can't find any set screws holding the cover on. It seems the cover just slides up and off but it is stuck. Anyone know how this cover comes off so I can disconnect the wires.
If I remember correctly the control box has a cover that slides up and over an open box that holds the control board. The last one I opened had a single screw in the top middle forward face. Remove that screw and the cover slides up and off. Wiring should enter from the bottom. I had to use a bit of force to get the cover off as it is a tight fit.
