Threads: 9
4
Home Port: Daytona Beach, FL
Vessel Info: 2000 Tiara 3500 Open
Cummins 6bta -370
I honestly don't remember as they have been installed for over 2 years now. But remember, breakers and fuse are sized for the wiring used. Wiring used is sized for the load that it is running. So I used 10 gauge wire so I am going to assume my breaker would be a 30amp breaker. Its been so long i forget what I used for wiring and breaker but I can check next time I am at the boat.
Threads: 1
Home Port: Newport Beach,CA
Vessel Info: I work for the Westcoast Tiara dealer Silver Seas Yachts. I'm one on the lucky few who gets to try all the models and engine combos.
01-05-2017, 04:00 PM
(This post was last modified: 01-05-2017, 04:27 PM by bigboatben.)
I would go with the Lumishore SMX52. I've never had good luck with the sea blaze. I always seem to get water in them and short out. I've never had any problem with the lumishore surface mount products. The 52 has Great light dispersion is dead simple to wire in. The hole in the transom is very small. You can use a proxy resin in the hole thru the hull to seal the core along with a healthy dose of marine sealant. I'm not sure if I would use 5200 in case you ever have to remove one. Maybe a sealant in the 4000 range. If you go with the SMX52s or any SMX light make sure you buy one master light. Any additional lights should be slave configuration.
One more thing The factory website has a configuration tool where you can see what your boat will look like with the different strength lights installed.
Threads: 4
Home Port: Lake Michigan
Vessel Info: Tiara 3100 Open 1989
Twin 454
I put 6 lights underwater in blue!
