Tiara Open Starboard Trans whine at idle
I have a 2004 35 Open with 8.1 Crusaders and ZF Transmissions.  I do have trolling valves installed.  The starboard trans has always whined at idle in forward only.  Above 900 rpm or so the whine disappears.  I talked to ZF Marine and they said this is normal as that tran spins in reverse due to counter rotating engines.  It seems to be getting louder and I have seen some threads to replace tran oil with 15W-40 engine oil.  Anyone have similar issue or suggestions?
I have same engine and trans but had the clatter at idle so I drained and filled with 15-40 which got rid of all the clatter but I believe might have slowed my top end speed by several mph. Replacing with 15-40 is common with the ski boat crowd but only certain transmissions and I have not seen where zf has approved a zf63a for the switch assuming that is what you have. I plan on trying 5w20 next as that's about as close to atf as engine oil gets.
Interesting because I have the same whine but only noticeable after a good run. 45 mins or so. Coming off plane and you start to hear it when you drop below 1K RPM.
  Differences in Port and Starboard ZF Transmission pressures and temperatures rmsullivan1@gmail.com 3 3,127 12-19-2024, 08:43 AM
  [Tiara Open] Trans Cooler Replacement Project 2700 open peakay 5 5,815 01-05-2022, 05:11 PM
Last Post: Joeboch348
  Trans Noise (Clanking) at Idle while in Neutral dsendre 3 4,667 05-07-2019, 08:56 PM
  Air Idle Controller Northporter 2 3,805 11-02-2015, 09:09 PM
Last Post: Northporter
