Prop shaft adjustment on Hurth HSW 630 V1
Upon inspection of the mechanicals before our next trip I noted that the lock nut on the prop shaft exiting the transmission was loose. The V-drives are coupled to 8.1 Crusader engines. I retightened the locking nut, but noted that the primary nut was not tight, but could be adjusted.  I searched for the specifications on the prop shaft adjustment/tolerances but could not find any information related to this specific area.  Any guidance or information would be appreciated.  Thank you in advance.
  Prop Size Older 31 Open duchess 2 3,598 11-01-2023, 08:40 PM
Last Post: duchess
  [Tiara Open] change tran fluid and filter on hurth waycamp 4 3,984 09-13-2023, 10:19 PM
Last Post: Joeboch348
  Prop Sizes rbutler1178 3 3,592 05-27-2021, 07:14 AM
Last Post: lakesidevu
  Transmission Damper plate on 8.1 L w/ Hurth MTULL 1 3,386 12-15-2015, 03:19 PM
Last Post: Uhehner
  Hurth / Mercruiser Transmission aksmith 0 2,713 07-08-2014, 09:06 AM
Last Post: aksmith
