US Coast Guard Documented Vessel
Does anyone know if the 3100 Open is greater then or less then 5 tons as described by USCG Vessel Documentation ?
My 31 Open was documented. The catalog states an approximate dry weight of 10,500 lbs. Net tonnage is a measure of a vessel's volume. It should not be confused with the vessel's weight, which may also be expressed in tons. Most vessels more than 25 feet in length will measure five net tons or more. Capt. George
The weight of a vessel and Gross Tonnage are two different measurements and are easy to confuse.
Per Wikipedia Tonnage is a measure of the size or cargo carrying capacity of a ship. The term derives from the taxation paid on tuns or casks of wine, and was later used in reference to the weight of a ship's cargo; however, in modern maritime usage, "tonnage" specifically refers to a calculation of the volume or cargo volume of a ship. Tonnage should not be confused with Displacement which refers to the loaded or empty weight of the vessel itself.
My 36 Sovran has a weight of 23,000lbs and gross tonnage of 24. You can find the documentation data on any vessel at the following web site. http://www.st.nmfs.noaa.gov/st1/CoastGua...yName.html
Hope this helps.
I would think a 31 is greater than because my 29 is 10,500 and is documented with the Coast Guard.
The Marine title company I used for the transaction did the USCG documented vessel application and calculated the gross and net based on the USCG formula. Based on that formula the 3100 came in at 14 gross and 11 net tons.
Can anyone help me with the gross tonnage for a 2001 38ft Open?
The gross tonnage for my 2003 38 Open on my documentation papers is: 25 GRT and the net tonnage is: 20 NRT.. Hope this helps
  Muskrat guard Toughship 1 1,945 02-04-2021, 06:50 PM
Last Post: Maxwell
Today 06:45 PM
» Replies: 5
Today 05:45 PM
Today 02:44 PM
» Replies: 8
Today 02:43 PM
Yesterday 08:09 PM
