Tach replacement 1995 33' Open
[attachment=551]I am looking to replace the tach's on my Tiara because they are jumping.
Connections are clean...
Anyone know the current replacement VDO line?
Thank you[attachment=550]
[attachment=552]the twist lock mounting is hard to find
Hello,
Before you buy new ones, see if you can locate the switch on back that is used to select the number of cylinders. Note where it is presently set. Take a small screwdriver and rotate the switch back and forth thru it's range several times and put it back where it was originally set.
See if that clears the problem. Often, those contacts corrode and can cause that problem.
Regards,
Paul
Thanks.
Did the turning of the switches a few times as well as replaced belts.
Seams to have solved the issue.
(08-11-2019, 04:42 PM)Mydiamond Wrote: I am looking to replace the tach's on my Tiara because they are jumping.
Thank you
I think they are VDO Blue Line.
Capt.  George
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 2 456 10-05-2026, 11:57 AM
  38 open bathroom recessed light bulb twilson0929 3 604 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 469 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 441 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 887 07-07-2026, 08:13 AM
Yesterday 06:13 PM
Yesterday 06:13 PM
Yesterday 06:10 PM
10-28-2026 10:32 PM
Last Post: Gustaf
10-28-2026 01:07 PM
