4100 Open raising the helm floor
Greetings All,
I am doing an in frame engine overhaul and need to raise the helm floor to access the engine.  I removed all the screws, bolts and furniture and the deck it's ready to raise.  I plan to use (4) eyebolts at each of the corners and build a A-Frame/gantry to raise it.  Has anyone done this before or do you have a better idea?
Thanks in advance.
Tim
Vessel "Do It Now"
I had a 43 Open which is similar. I guess you could try to lift the floor from the ER with some jacks, then maybe brace the floor with some 4x4's while work is under way. Only other option I can think of is to get a forklift in there and remove the whole floor section. My boats PO had to pull an engine and obviously the floor had to come all the way out.
I'm surprised the floor has to be raised to do an in-frame. Tiara didn't leave enough room to pull the head?
I have to machine the #1 cylinder and they need 3' clearance. I'm having the yard forklift the lid out.
Thanks for the response.
(10-12-2020, 08:48 PM)jclark003 Wrote: I had a 43 Open which is similar. I guess you could try to lift the floor from the ER with some jacks, then maybe brace the floor with some 4x4's while work is under way. Only other option I can think of is to get a forklift in there and remove the whole floor section. My boats PO had to pull an engine and obviously the floor had to come all the way out.
a question to 43 owner.  Did any of you ever pull out the "L" shaped aft seating to allow for open aft area?
I removed the furniture and lid to pull the engine for a complete out of boat overhaul.  Freaking Cat 3126B's!
quote="hookup44" pid='14903' dateline='1602809163']
[/quote]
  38 open bathroom recessed light bulb twilson0929 3 431 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 347 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 701 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,326 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 726 05-12-2026, 10:18 AM
4100 Open raising the helm floor00
