Tiara Open fuel filters
I have a 2004 29 open with 5.7 crusaders.  Anyone have an issue changing the gas filters.  I have the original spin off canisters that house the fuel pump and filters.  Can not get them off.  This winter I will have to take off entire system from engine and attempt to put in vise and spin off. Concerned about damaging the canister .  Any hints?
Are you using an oil filter wrench to get it loose? I've never had one I couldn't get off.
yes , but they wont budge....
If you have a wrench on them try twisting as hard as possible and hold it for 20-30 seconds often filters begin to slowly lose there grip. I've had this approach work countless times. It's all about getting the rubber seal to let go and it just takes time.
Make sure you have the wrench all the way at the top of the filter. And remember righty tighty, lefty loosy. Constant pressure at the top till it breaks loose.
I will try again but afraid I will damage the canister.  I may remove form bracket and put in a vise to try to free it...
If your using the oil filter wrench which is a band, you shouldn't damage the filter. If its got teeth and can crush the filter, go buy a band style one.
  Upgrading to fuel injection Joeboch348 1 1,085 11-26-2025, 12:14 PM
  [Tiara Open] Raw fuel smell while running WOLFDAWG71 3 1,297 11-19-2025, 07:43 PM
Last Post: Joeboch348
  Fuel Filler Hose Joeboch348 1 808 08-18-2025, 04:24 AM
Last Post: Capt. Paul
  [Tiara Open] 454 XLi Low voltage at electric fuel pump Mtgates44 3 1,831 04-27-2025, 10:19 AM
Last Post: Mtgates44
  Low Fuel Light ?? Pluto 7 8,481 07-30-2023, 04:05 AM
Last Post: MuskyHuntr
fuel filters00
