Tiara Open Leaking Shower Control on 3200 Open
After finding my toilet paper roll soaked a couple times after using the shower I finally discovered why.  The shower control is leaking somewhere in the back.  Has anyone removed this?  If so, how?  There isn't much room to work with even after removing the small access panel inside the cabinet.  Any tricks to this?
Dan
Tiara used delta faucets. It may be the cartridge is leaking. I have been able to find replacements st Home Depot as well as the puller to remove them with.
The control is an Italian Barka model that is leaking. My problem is removing it to either repair or replace. Has anyone done this?
  2900 open - a/c water pump not running North000 2 1,704 06-22-2025, 02:18 PM
  [Tiara Open] Shower sump pump lakesidevu 2 1,872 05-26-2025, 08:29 AM
Last Post: TenBayFive
  New AC install on 1985 3100 open CaptChris2334 1 2,514 03-30-2024, 01:25 PM
  41 Open AC water pump vapor lock esf 3 2,391 08-07-2023, 04:07 PM
Last Post: esf
  1993 4300 open waste and water level indicators bpro 1 3,264 08-07-2023, 08:31 AM
Last Post: esf
