Threads: 26
Home Port: ny
Vessel Info: 2001 43 open sport,cat 3196
on my 43 open,I have an issue with some 120 volt outlets do not work when the shore power is in the 120/30 amp supply cord to shore power.When plugged into the 50 amp 220 shore power they work,,,,is that supposed to be like that?
Threads: 3
20
Home Port: Lake Michigan
yes you should have power to all circuits in the AC panel. The 120/30 will provide power to everything in the boat but doesn’t provide enough amps to run everything at the same time. For starters I would check for tripped GFI’s. Also check the panel and see if the breaker for the outlets is not tripped and that the indicator light is lit.
Threads: 8
10
Home Port: Port Canaveral, FL
3406E Cats
Do you have 2 120v shore inputs? If so are you only using one of them? On an old boat I had if I used only one it cut out some of the electrical systems. Once both were connected everything would work.
Sans Peur 2003 Tiara 50 Open
