3500 Open Trumpet Horn
Hello,
I have a 2004 3500 Open. I need to change the dual trumpet white epozy situated on my hardtop. Does anyone know the model for the replacement? The model I have has the two dishes with horn componenents laying flat on the topside. When I google AFI horns all of the similar like horns have components upright on the back of the two trumpets. These will not fit my fairing block...HELP please!!! Thanks, Jim
(09-21-2015, 04:30 PM)bigblueh20 Wrote: Hello,
Btw, in doing some research it looks like a Fiamm horn...still not sure which model...
I own a 2003 38 open w/twin air horns on the hardtop as well... Mine are from FIAMM Technologies. Here's the web site:
http://www.fiamm.com/en/northamerica/avv...logie.aspx  Assume the ones on your 35 are the same.
After you Google FiAMM HORNS click on "images" and see if one matches up.
Sounds like you have a Fiamm Fultone II Twin Trumpets Horn.
While we are on the subject of air horns, my FIAMM horns are fine but I think my compressor is failing. The horns sound great if you blow through them with your mouth or a compressed air source. They just sound lame and weak when the boats compressor is used. The compressor seems to pulse instead of develop a solid burst of air. Is this normal or is it a sign of a bad compressor? Thanks.
Sounds like a compressor problem. Squirt some oil into the tube fitting and try it again. I had to do that once a season. Capt. George
  2001 38’ Open interior table base removal twilson0929 3 909 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,531 05-22-2026, 06:41 PM
