36 2006 open
Removed the helm seAt and had it re upholstered. The paint on the fram was pealing so I had it powder coated. Re installed with the magnets lined up but engine hatch switch will not activate . Connections all look good but does not seem to be getting power to switch. Thanks
Author's Statistic:
Threads: 14
Likes Given: 1
Home Port: Kings Park, NY
Threads: 14
Likes Given: 1
Not sure which Tiara you own but I have a 2003 38 Open and I need to remove the jump seat on the "L" shaped settee (port side or boat) to allow the hatch to lift... Mine is magnetic as well.....
12-21-2016, 09:51 AM (This post was last modified: 12-21-2016, 09:52 AM by firstlight.)
(12-21-2016, 08:41 AM)ReelMagic Wrote: Not sure which Tiara you own but I have a 2003 38 Open and I need to remove the jump seat on the "L" shaped settee (port side or boat) to allow the hatch to lift... Mine is magnetic as well.....
Yes I removed seat, I wish it was that simple Thanks for reply
Author's Statistic:
Threads: 14
Likes Given: 1
Threads: 14
Likes Given: 1
At this point I would jump out the seat switch..... Can be easily done
