Repairing leaks to opening window on 3100 Open
I’m awaiting the gasket material to try to stop the leaks at the opening window on my 2000 3100 Open.
The written material from Tiara has me confused. Maybe it will make more sense when the gasket arrives and I have it in my hands. maybe I’m getting to old for this stuff ?
Does the gasket go on the opening window? The fixed frame? Both? Do I unscrew the opening window at the power arm to allow myself to get to the underside of the window more easily?
Has anyone put this operation on You Tube?
Thanks. Love the boat, just purchased it a few months ago. The rain water flooding in is driving me nuts..
Bill
Punta Gorda, Florida
Have you checked the window frame drains for blockage? There should be two drains for the center window. Bob
I had the same problem. Used a piece of 200# mono to snake out the drain holes-worked. Solved the problem and saved the hassle of replacing the gasket, which wasn't even the cause!
(06-25-2018, 06:55 PM)drifter Wrote: I had the same problem.  Used a piece of 200# mono to snake out the drain holes-worked.  Solved the problem and saved the hassle of replacing the gasket, which wasn't even the cause!
Also had same issue with blocked drain holes....used thin picture wire and pushed thru quite a bit of dirt.
No more leaks.
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,333 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,796 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,556 05-25-2025, 08:25 PM
Last Post: Roweje
  Trailering a 32 open douellette48 3 2,901 02-07-2025, 08:46 PM
Last Post: Hifirush
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 7,147 12-02-2024, 09:25 AM
Last Post: Hooper
Repairing leaks to opening window on 3100 Open00
