Leaking ports
Anyone have any experience removing and rebedding the ports on the hulls sides? My 38 has 3 on each side, and not only do I have rust stains down the hull sides, I have some staining on the vinyl liner inside underneath the ports.
G.G. Schmidt and Sons, (888) 252-5446, have just about everything you would need to repair your port lights.
Good luck.
I've done mine twice. Easiest with boat out of the water. Unscrew from the inside. Then from the outside use a razor blade to cut the silicone that seals the joint between inner and outer frames. Go back inside and slowly pry the frame away from the wall. Cutting the silicone all the way through is the key. Then push out the external frame. Once you have it all apart, it's pretty clear what to do next. Use something like 3M 4000UV for the external frame to hull joint, and clear Marine silicone between the frames.
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,391 05-22-2026, 06:41 PM
  1993 Tiara Sport 220 Fuel in the Bildge (Leaking tank) bradcool 1 861 01-21-2025, 08:50 AM
  Center windshield still leaking brad 2 2,062 07-17-2023, 07:52 AM
Last Post: brad
  [Tiara Open] Fresh water tank is leaking kphodgins 6 5,392 11-09-2022, 02:42 PM
Last Post: lundtooth@hotmail.com
  Troubleshooting root cause of oil leaking at shaft hub Toughship 2 2,585 10-03-2021, 04:48 PM
Last Post: Toughship
Leaking ports00
