Tiara Open Tiara 3800 Open Fuel Guage issue
I have 2002 3800 Open(dual tanks and guages) My port gauge is working but my starboard gauge stops at 3/4 tank and will not go lower.  When I fill the tank, it does go back to full but when it reaches 3/4 it stops.  Any insights as to what could cause this and if there is a fix are appreciated.
Cheers.
I posted a reply a few days ago on how to troubleshoot a fuel gauge, you might want to go look at it.
To test the fuel gauge, disconnect the pink wire (sender). Turn on your ignition switch. The gauge should read empty. Ground the pole where the pink wire went to the black wire and it should read full. If both of those are true, your gauge is fine. Reconnect the pink wire. You then need to check at the sending unit. Disconnect the pink wire and ground it out. If that works you have a bad sending unit. If it doesn't work you have a wiring issue.
  Tiara 52 Sovran Salon Keel Question Knot On Call 1 134 08-05-2026, 01:16 PM
Last Post: Splendor
  2001 38’ Open interior table base removal twilson0929 3 529 07-07-2026, 08:13 AM
  Freezer Replacement for 40' Tiara Reprise1 4 1,502 06-09-2026, 02:28 PM
Last Post: fuzzy
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,178 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 656 05-12-2026, 10:18 AM
Tiara 3800 Open Fuel Guage issue00
