Rebedding Portlight
I have a portlight that needs rebedding. I am looking for recommendations on which silicone to use.
Dow 795 came highly recommended, but doesn't setup and bond well in cooler temperatures.
My boat is stored indoors, but in an unheated warehouse. I plan on starting in March, so the temps will likely be below 50 degrees up here on Lake Erie.
Any suggestions?
I would not use a silicone as a bedding compound unless you are setting glass into a frame. I think Tiara uses Bostich 920, a urethane base construction adhesive similar to 5200, for most of their hardware bedding. Either one of these will provide a permanent seal/adhesion and are moisture cured so should be ok applying in a cool environment. Boatlife life caulk (polysulfide) will allow you to remove the porthole easier in the future if so desired. Butyl tape also works well for bedding and is easy to work with.
(01-12-2020, 10:07 PM)jclark003 Wrote: I would not use a silicone as a bedding compound unless you are setting glass into a frame. I think Tiara uses Bostich 920, a urethane base construction adhesive similar to 5200, for most of their hardware bedding. Either one of these will provide a permanent seal/adhesion and are moisture cured so should be ok applying in a cool environment. Boatlife life caulk (polysulfide) will allow you to remove the porthole easier in the future if so desired. Butyl tape also works well for bedding and is easy to work with.
Thanks. I was hoping to avoid 5200 or comparable adhesives because should I need to rebed in the future (very likely), I don't want to bend the outer frame of the portlight trying to get it off. I'll check out Boatlife's products.
  Mid 90's 31 Open portlight Plexiglass shades rafredrickson 1 2,519 09-24-2022, 04:48 AM
Last Post: jgreenlee
  [Tiara Open] Portlight replacement screens and gaskets mradigan 1 2,757 05-05-2017, 04:45 PM
  Mid 90's - Open Portlight shades - plastic rafredrickson 0 1,846 08-14-2016, 03:31 PM
Last Post: rafredrickson
  Bomar hatch and Portlight cjay 1 3,839 02-17-2013, 09:07 AM
Last Post: Dennis
Rebedding Portlight00
