Threads: 26
Home Port: ny
Vessel Info: 2001 43 open sport,cat 3196
I have an air horn compressor problem,replaced it twice,still seems to be no getting enough amps,ran a temp wire direct to battery and worked fine.Could it be that the wire that tiara used was not heavy enough?
Threads: 8
10
Home Port: Port Canaveral, FL
3406E Cats
Check resistance on the wire and switch. Either or both could be corroded and causing a problem.
