Tiara Open 1995 Tiara 43 Open water tank and door/stairs removal
I need to cut open the interior cabin floor to remove the 100 G water tank and 61 G waste tank, which both have developed leaks.
1. Does anyone know how to remove the steps / module that lead into the cabin?
2. Any information on how to remove the entry way door?
Many thanks in advance for any suggestions.
You may need to ask Tiara. On my ‘01 43 there was a molded cover to the left of the slider that I believe is set in with an adhesive and screws. Pretty sure it wraps up and around the map box and looked to me to be a real job to get it out.
I tried unsuccessfully to get my stairs out. According to Tiara there is access to the mounting screws once you pull out the treads. Turned out not to be true on my vintage as the stair moldings were totally sealed. Only way in was from ER behind electrical . If you pull the courtesy light out of the stair molding you should be able to see inside and if pulling the treads will give you the necessary access.
Sorry to hear about your tank issues. My friend had the same issue with holding tank and I ended up replacing both fuel tanks. I hold Tiara in the highest regard except for the decision to go cheap on something so important and inaccessible as tanks.
Maybe consider hanging a bunch of Moving blankets and bring in a plasma cutter. Then have new tanks fabricated in place or made in such a way to simplify installation.
I have a 3100 Open but had an issue with water entering the cabin area.
I was convinced it was a leak in my water holding tank.
After 1 year of trying every angle possible I finally discovered the water source.
I was in the anchor box...specifically the bond between the drain plug fixtures and the glass.
At close inspection I was able to see a crack in the bonding material (maybe 5200).
I sanded/cleaned and resealed with either 5200 or 4200.
No more leaking for me.
The water that builds up under the wood floor is no pleasure removing given there is no clear drainage path.
Disregard if a NA.
I feel your pain but not to your level.
Best
Thanks for the info and suggestions. Tiara actually sent me some information, although they are still suggesting there are screws under the stair threads but I already know that is not the case. They did also suggest I remove the trim at the stop of the stairs, which I will do next week.
  38 open bathroom recessed light bulb twilson0929 3 486 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 386 08-18-2026, 02:11 PM
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 519 08-17-2026, 05:31 PM
Last Post: Bford100
  bathroom door handle fuzzy 2 499 07-18-2026, 05:43 PM
Last Post: fuzzy
  2001 38’ Open interior table base removal twilson0929 3 765 07-07-2026, 08:13 AM
1995 Tiara 43 Open water tank and door/stairs removal00
