Oil pressure alarm going off
I have twin gas crusader 454 XL engines.
While running I had the oil pressure light and alarm come on.
I checked the oil and topped off the oil.
Ran it again, after about 20 minutes running 2800, alarm went off again.
Checked oil. Level is fine
Low rpm’s - engine runs fine…. No alarm.
New sending unit last year (from diagnostics of another issue)
Erving up in the slip, gauge jumped from 50 to 60.
Any thoughts on next steps?
Thank you
Typically on those engines there is a separate switch for the OP alarm/warning light. It is sometimes mounted to a tee along side the oil pressure sender. If you are showing good oil pressure and simultaneously getting a low OP alarm that is usually the culprit.
Added picture
Looking for part number for crusader 454 XL - gas
Oil sending unit
Closing out the thread
At the left rear bottom of the engine There is the low OP alarm sensor with one pole connection.
The wire connection was corroded causing a false read
Thanks jclark003 for the lead.
Another forum success..
Video [Tiara Open] Check engine light and alarm at cruising speed bcgettel@gmail.com 2 1,926 06-28-2023, 08:16 AM
Last Post: rcwiegand
  Raw water temp alarm on closed cooling crusaders cp4000 0 1,235 05-30-2023, 03:15 PM
  [Tiara Convertible] 1996 454 Crusader Fuel pump pressure switch seahagbrewing 0 2,454 06-17-2020, 02:50 PM
Last Post: seahagbrewing
  8.1L Crusader Check Engine Light and Alarm rcwiegand 3 7,203 07-13-2019, 01:35 PM
  Fuel Pressure Regulator O-Ring on Crusader 8.1 MPI ddfour1 0 2,631 05-23-2016, 03:47 PM
Last Post: ddfour1
Today 02:44 PM
» Replies: 8
Today 02:43 PM
Last Post: joshuaseward
Today 11:40 AM
» Replies: 4
Yesterday 08:09 PM
Yesterday 07:59 PM
