Head issues
Need to know how to fix head
It backs up with water from raw water after I flush
You flush n minutes later nasty water a few inches is there
Plz help
What type of system to do have? Is it a Vacuflush? Can you confirm that the "Raw" water you mention is actual sea water or are you drawing water from the fresh water tank?
(02-07-2022, 09:52 AM)Matta0413 Wrote: What type of system to do have?  Is it a Vacuflush?  Can you confirm that the "Raw" water you mention is actual sea water or are you drawing water from the fresh water tank?
The water is staying in head so it’s what I’m trying to flush it gets clear then after a moment dirty water remains like it’s not getting to raw water tank ok or coming back from there
It’s a 31 ft tiara open with a vacu flush
Is the waste tank empty? If so, I’d replace the duckbills. Might want to do a pump rebuild too while you’re at it (not that bad a job).
Can you hear the vacuflush pump working? Does the head make the loud sucking sound when you flush it? Was it working properly at one time and now it is not? As previous poster mentioned, it maybe time for a pump/tank rebuild. Not a tough job but certainly a messy one.
  [Tiara Open] Water under Quartz flooring in head benmaser 0 621 06-16-2025, 02:24 PM
Last Post: benmaser
  Steering issues with engine down Capt. Tom 3 1,955 10-23-2023, 09:00 AM
  [Tiara Sovran] Hull Delamination Issues Five Gulls 1 2,224 03-27-2023, 09:04 PM
  Cabin Head Liner TIARA44 1 2,901 09-25-2022, 10:23 AM
Last Post: jgreenlee
  2002 - 31 Open AC Pump Issues Matta0413 2 1,777 08-12-2022, 09:13 PM
Head issues00
