Tiara Sovran Charger to charger/inverter upgrade
2007 43 sovran. I need a new battery charger and I see a spot to install a switch similar to the battery switches marked "inverter" and am wondering how much wiring would be necessary to complete the setup? thanks
Very interested in the responses because of what I’ve gone through recently. I figured it would be 1. Replace existing charger with inverter (using existing wiring), 2. Add a switch and fuse, 3. Run some AC wiring to the panel. Done. Figured a buddy and I could do it all in half a day.
But out of a lack of time, I had a couple companies give me estimates, and it’s upward to $7-10k. Insane for what I see as $1500 for an inverter and a couple hundred bucks for AC wiring. Everyone wants to run new wiring out of the battery bank. That and what seems like an excess amount of labor has me confused about the whole process.
Are they greedy or am I underestimating the true amount of work?
One of the big expenses is the new DC electrical subsystem that needs to be installed.  You need to run new DC wiring and appropriate circuit protection from the batteries, through the new inverter switch at the panel, to the inverter.  The reason you need new cables is that even the smallest inverter/charger you are likely to install draws much more DC current than your existing charger supplies to the batteries.  The cables you will need depend on the size of the inverter and the distance from the batteries, but they are likely to be 'huge'.  Huge cables are expensive to buy/make, and time consuming to properly route and support.
Then there is the task of properly tying it into the AC system.  This can be complicated depending on the existing AC system.  Is the existing AC system just a single phase 120v shore power input?  Or, perhaps it is multiple shore power inputs including 240v split phase, 120v single phase, and a 240v split phase generator?  What load(s) do you want the inverter to be able to run?  A single AC load, select AC loads, or all AC loads?  The answer to these questions can have a significant impact on installation complexity.
Then there is the matter of supplying adequate energy to the inverter.  Depending on what you're going to do with the inverter, it is quite likely that you will need to increase the size (and possibly the chemistry) of your battery bank.  That said, a properly designed and installed inverter system is great to have on a boat.
  1995 3500 Express LFP/Inverter Install penneyma 0 42 Yesterday, 07:09 PM
Last Post: penneyma
  Pantographic wiper Upgrade Dakota773 3 4,507 07-13-2016, 07:55 AM
Last Post: Silver Rush
Charger to charger/inverter upgrade00
