Windshield Washer solenoid location 02-3100
Where should I be able to find the windshield washer solenoid on a 2002 3100 Open?  Issue is that the washer pump will not shut off completely, and washer fluid trickles from nozzle continuously.
When the dash switch for washer is activated, the pump works as intended.
Thanks for any suggestions.
May I suggest that you remove the solenoid and try cleaning it.. I suspect there's dirt in it... M2C
My 35 Open did the same.  The solenoid was in front of the starboard engine on mine.  I never used the washer system, so I turned off the inline valve before the solenoid.
There’s a repair kit available for the solenoids. They’re very easy to dismantle and repair. I found it on a. Website called sloanrepair. They’re the same valves that turn on the water in most electric restrooms sinks. Just shop around. One kit cost $67.00. I bought two more on Amazon for about $25.00 each.
ON my pervious 31 Open (1997) the solenoid was in the engine room on the forward firewall starboard side.... There's 1 solenoid on the 31... It has a clean out plug. I'd take it out and clean the solenoid. M2C
  Windshield Leak tip TIARACRREP 35 42,077 09-23-2026, 11:53 AM
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 494 07-28-2026, 06:28 AM
Last Post: Tiara45
  Windshield Wiper Arms and Blades Lafobrian@gmail.com 17 16,504 06-20-2026, 11:59 AM
Last Post: nylakeshome
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 3,097 04-19-2026, 06:48 PM
  need to replace solenoid for the windlass how to I get my fat ass into the anchor sluggo 3 2,108 04-19-2026, 06:46 PM
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
