Transmission Oil Change
6.0l Crusaders with ZF Hurth Xmissions
Manuals have some conflicting information on changing the transmission oil. Here is what I believe is the process. Please correct me if I am wrong.
1. Start engine and get the oil flowing in the lines to the oil cooler and in the cooler.
2. Stop engine and ASAP check the oil level (without screwing the dipstick back in) before the oil in the cooler and lines can flow back to the xmission. This is done so that when running the level is measured with oil in the lines and the cooler and filled as indicated by the dip stick. If not done this way and the oil has flowed back to the xmission the level will be low when the engine is running and the lines and cooler are filled.
3. I will note that the measuring portion of the dipstick is close in color to the fluid making it difficult to see just where on the dipstick the oil level is.
Appreciate comments on this. Thanks.
That's pretty much it. After you do it once you'll know the correct amount the next time so you won't have to go through the measuring procedure again.
(02-25-2017, 06:51 AM)YOLO Wrote: That's pretty much it. After you do it once you'll know the correct amount the next time so you won't have to go through the measuring procedure again.
Thanks YOYO>
  [Tiara Open] Zf280 transmission pressure twilson0929 2 962 08-11-2025, 07:19 AM
  Power issue livewell and oil change pump smagistro 1 754 04-22-2025, 06:07 AM
  oil change system honest mark 6 8,443 01-20-2023, 07:32 AM
Last Post: MC1600
  44 Coupe - change to different anchor? kysloc4 3 3,588 12-03-2022, 10:40 AM
  Transmission Fluid Venting through hull desjef 3 5,693 08-05-2016, 02:19 PM
Last Post: desjef
Transmission Oil Change00
