1990 33 open
Can anyone tell me about auto pilot on a 33 open. Looking to buy one used if possible. What should I be looking for?
You should just buy the 3900 Sovran that's docked next to you...
You will need a hydraulic pump motor, compass, display head and computer. Maybe a rudder reference unit. Then it needs to be interfaced to your GPS / Chartplotter. The hydraulic lines need to be tee'd in and bled and the power lines and circuit breakers installed. The compass needs a magnetic interference survey and alignment and dockside sea trials must be done. When installed correctly the results are fantastic. I have seen lots of autopilot problems caused by botched installations. Unless you have lots of experience in these areas I would shop for a good tech. Furuno & Garmin make great units, I rarely see a good used one. Capt. George
Auto-pilots are set up according to the type of vessel they are being installed in. If you are looking for a pre-owned autopilot, you need one for a twin engine inboard planning vessel from 30' to 40'. Obviously an auto-pilot for outboards won't have the correct set up or the correct sized pump. Same with smaller inboards or single engine applications with only one rudder. Once you find a pre-owned unit, look it up to see what the parameters are.
Make sure it is compatible with your electronics. If you have 2000 electronics, and you buy a 2010 auto-pilot, you likely will not be able to set up waypoints and routes. same goes for the reverse newer electronics and older pilot.
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,160 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,564 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,363 05-25-2025, 08:25 PM
Last Post: Roweje
  Trailering a 32 open douellette48 3 2,577 02-07-2025, 08:46 PM
Last Post: Hifirush
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 6,761 12-02-2024, 09:25 AM
Last Post: Hooper
1990 33 open00
