Threads: 2
Home Port: Marion, Massachusetts
Vessel Info: 2006 3200 open
06-18-2018, 08:17 PM
(This post was last modified: 06-19-2018, 05:44 AM by Snowballs.)
Westerbeke advises having a dedicated start battery for generator. Factory supplied tied to house batteries (2). Seems to be causing issues with electronic governor - runs fine for 30 minutes then hunts and shuts down. Should add batteries are borderline due to yard over charging. Looking for advice on running Centaur ac powered battery charger when on generator power knowing generator has a built in charge circuit so in effect both gen and charger supplying charge to house side.
Threads: 4
Home Port: long island
Vessel Info: 1998 3500 Open , 7.4 XLI
Did you ever get more information on this? I have the same genny and the same problem. Runs well for 30 mins then starts to hunt and eventually dies. I have to check and verify my battery wiring. I may just try and run it with out the onboard charger operating and see if that takes care of my issue. Did not think that they both would be charging.
98 3500 open
Threads: 4
I will dig deeper into my set up and see if I can isolate the problem. I have changed 2 fuel filters and the plugs, same symptom. Runs well for 30-40 mins under load then starts to hunt and eventually dies. Temps are good and have good water flow. I will run the system without the dedicated battery charger on and see what/if this changes. Then test the batteries to see what the generator is charging. I know that mine is connected to the house bank battery (or so it appears). There is a nice group of wires and ill have to dig deeper. Seems easy enough to add a single battery for the genny. I will report my findings.
TY
