C-PAP keeps tripping GFI
Every time I plug my c-pap into the outlet in the forward birth on my 3700 the GFI trips.  I tried plugging in other thing and it is fine. I even tried all of the other outlets on the boat and every time I plug in the c-pap it trips the GFI. I am using a single 30 amp shore power cord and was thinking about trying the 50 amp cord to see if that makes  difference.  Any thoughts would be appreciated.
Dennis (aka sleepless in Michigan)
I doubt switching to the 50a cord will change anything. your c-pap machine may be leaking a little current. Try plugging into a gfi outlet at home and see if it trips the fault breaker there.
Thanks, I'll give it a try.
Well I tried the 50 amp cord by using a splitter from two 30 amp outputs to my 50 amp line and it worked great. I was able to use my C-pap machine without an issue.  Thanks for all who helped with their suggestions.
  Spreader lights tripping fuse.... bpy 5 6,657 06-12-2014, 11:18 AM
Last Post: Uhehner
