RPM issue on 2700 Tiara
#11
Understood. Will let you know how it all goes...again, thanks.
#12
I had a similar issue in my 1995 454 Crusaders. Ultimately discovered the culprit was a faulty anti-siphon valve in the fuel tank.
#13
(11-09-2012, 09:42 PM)Uhehner Wrote: I still don't understand the fuel consumption and carburator issue yet but get the engine running correctly first.  I would purchase a new distributor module.  This was my guess on 11/9. Next, be sure to set the timing correctly using a timing light. If you set it too low, your mileage goes down. If you set it too high ( degrees before TDC ) you will burn up a piston. Time both engines.  Capt.  George
You also may want to change the water separator on that side. I also havea 1989 Tiara 2700 Open and seemed to have the same issue a while back
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,052 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Tiara 31 open crusaders getting when WOT aliyilmaz 5 6,499 03-03-2025, 07:40 PM
  [Tiara Open] Repowering a Tiara 3100 Open with 2 outboards drake 2 3,571 08-21-2024, 09:09 AM
  39 Coronet Cummins generators issue d5dekeyser 4 3,910 07-28-2022, 08:53 PM
  [Tiara Open] 2006 Tiara 42 Open Transmission Kphillips 1 2,100 07-12-2022, 09:00 PM
Yesterday 06:45 PM
» Replies: 5
Yesterday 05:45 PM
Yesterday 02:44 PM
» Replies: 8
Yesterday 02:43 PM
10-26-2026 08:09 PM
