Prop Sizes
Hello,
I just purchased an older Tiara 3100 (1981) with 454 crusaders. The engines were replaced in 2003. The boat is sound mechanically and runs good. The problem is I am only able to get approx 3300 rpms and a top speed of 24.5 mph. Is this correct? I am wondering if the prvios owner changed the porps out. I would like to know the original size props. Anyone have an idea?
Rick
WOT should be in the 4400 rpm range, and I would think low 30's in mph.
If you contact Tiara Customer Support, they should be able to provide the prop size the boat left the factory with.
ardoski14 (05-18-2021)
My 1988 33' has 18 x 21 with the 350 HP 454 Crusaders. At 3200 I'm running about 26 MPH half tank and 2 guys.
[Image: NBvUYCDdQEqZfboL8]
[-] The following 1 user Likes ardoski14's post:
Misdirection (05-18-2021)
I believe that they came with the 19"x 20" nibrals,and WOT is 4200-4400 RPM depending on load
  Prop Size Older 31 Open duchess 2 3,426 11-01-2023, 08:40 PM
Last Post: duchess
  Prop shaft adjustment on Hurth HSW 630 V1 rwshevy 0 2,011 07-09-2018, 07:56 AM
Last Post: rwshevy
Prop Sizes00
