Threads: 41
I have a 1998 3100 open with dock side water hooked up i get water and then it stops like someone shut it off a few seconds later its back on at full preasure. Ive checked with others on my dock no problems water preasure at the dock is constant there is no filter on the incomming line any ideas would be appreciated
Threads: 14
11
Home Port: Kings Park, NY
The dockside water inlet in your boat contains a pressure regulator that limits internal pressure to 45-55 PSI. It's possible that regulator is failing.
Threads: 41
Turns out it was the preasure regulater comming into the boat replaced it and we are good to go. Thanks for the help
