06-18-2021, 01:27 PM
I just solved that problem with my 2004 3100. Problem was potentially three things. The anchor drain was definitely leaking but that water seemed to be contained under the bed. The shower sump pump was not working and there is an automatic bilge pump outside the shower sump that is supposed to pickup any overflow and it was not working. Good luck!
