Tiara Coronet Rudder Position
Question for the group on the proper rudder height.   The starboard rudder is positioned 3-4 inches higher than the port rudder.   Assume both should be at equal heights but not sure which is the proper height.
thinking the rudder position should be lower to get better water flow and steering but not sure.
Appreciate any input.
Attached Files Thumbnail(s)
I would reach out to Tiara and have them send you the rudder calibration specs. That should give you the X dimension and tow specs.
Off hand I would say the port rudder dropped down and the safety pin is keeping it from falling out, something you do not want to happen. Definitely would not run the boat until you get it figured out.
  [Tiara Open] 89 3600 open rudder needs replacing BurdenLSU 0 829 12-06-2024, 11:01 AM
Last Post: BurdenLSU
  rudder extensions honest mark 2 2,088 09-09-2022, 01:09 PM
Last Post: honest mark
  2001 3500 OPEN Rudder shaft seal size Crown Royal 0 1,423 05-02-2022, 03:17 PM
Last Post: Crown Royal
  Size for 3500 express Rudder packing inside nut neto 0 1,671 09-09-2021, 12:00 PM
Last Post: neto
  [Tiara Open] 1988 33’ Open Rudder Arm Play - Remove Pin? ardoski14 1 2,472 04-19-2021, 09:53 PM
Last Post: Bice0004
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
