Tiara Open 2004 Tiara 3500 Open
If you were to lose all power how do you lift the deck to access the engines?
CJH
(08-20-2024, 07:29 PM)cjh3500 Wrote: If you were to lose all power how do you lift the deck to access the engines?
CJH
Do you have openable ports through the aft settee?
I apologize i do not know what you mean by that.
I know what the aft settee is but what ports? Where might they be?
A few ways:
-Enter the engine room through the day hatch, fix the problem with the power, then lift normally
-Connect temporary power (e.g. jump pack, new battery, etc) to the hatch lift piston breakers behind the dash (only do this if you're familiar with DC wiring), lift the hatch normally
-Enter the engine room through the day hatch, disconnect the pistons from their upper mounts (pins), lift entire hatch by external means. Note that the hatch is extremely heavy and could easily kill or severely injure someone if it were to fall. I've seen people use heavy ratchet straps or even a forklift with straps.
  Tiara 40 Express 2003 - Removal of Cleat saywhen 1 303 10-27-2026, 02:43 PM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 489 08-18-2026, 02:11 PM
