Belt cover replacement
I have a 2008 Sovran 4300.  To check and replace the belts on the engine, I had to remove the large plastic covers on the front of the motor, covering the belts.  The port cover was relatively easy to remove and replace, but the starboard cover is NOT going back on even after 2 hours of attempts.  I removed the generator cover to make more room, but still there is no way to replace the cover exposing the belts and front of the motor.  Any help out there?  Thanks
Scott
I went through a similar issue on my 2003 38 Open w/Cummins 6CTA Diamond Series engines. I decided, after much trouble in removing the front  serpentine belt cover that it wasn't going back on... It's there for safety and to encapsulate  the belt should it break....I'll take that risk as it was nearly impossible to put the covers back on.. M2C
Thanks Reel....I was thinking the same thing.
I have cat 3208's and no belt covers. Doesn't effect anything and actually makes it easier to get to them. Leave them off, it will make your life easier.
I agree...thanks
(08-09-2018, 11:27 AM)mobil1 Wrote: I have a 2008 Sovran 4300.  To check and replace the belts on the engine, I had to remove the large plastic covers on the front of the motor, covering the belts.  The port cover was relatively easy to remove and replace, but the starboard cover is NOT going back on even after 2 hours of attempts.  I removed the generator cover to make more room, but still there is no way to replace the cover exposing the belts and front of the motor.  Any help out there?  Thanks
Scott
I have a 2009 Sovran with the same issue. Port side belt had been replaced by previous owner and that cover had been modified to be easily removed. The starboard belt had not been replaced. It took 45 minutes to get it off. Used a dremel to modify the cover to a similar shape as the port side. Common problem according to my Volvo mechanic
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 0 46 Today, 08:58 AM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 239 07-25-2026, 09:15 AM
Last Post: roboh20
  Freezer Replacement for 40' Tiara Reprise1 4 1,505 06-09-2026, 02:28 PM
Last Post: fuzzy
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 817 12-14-2025, 05:34 PM
Last Post: MariTime2
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 577 09-07-2025, 11:19 AM
Belt cover replacement00
