Tiara Open Volvo Penta Coolant Pumps
I am in Australia and have a 2005 Tiara 3200 Open and apparently the coolant pumps have started to leak. There are none in Australia and I am being told they would be about $1059 each plus tax and freight to source from USA. Freight is about $120 on top. ( This is Australian dollars ) Has anyone replaced them recently and have an idea on what they would be to buy over there if I were to try and source them myself ? Any help appreciated.
Engines are Volvo Penta D6-310I-A and the part numbers I have been given are 2 x VP22577750 Volvo Penta Coolant Pumps. If I can source them myself at a better price, the mechanic is happy to fit them for me but that is what he is getting from the agent here.
Of course they have recommended all the coolant hoses be changed as well but they are available here and about AUD $177 + tax here which is not as painful.
If you don't get an answer here hop on over to boatdiesel.com and you will probably get lots of good feedback and recommendations.
(03-23-2020, 09:28 PM)Orkun Wrote: [Only registered and activated users can see links Click here to register]
Contact these guys here in California. Tell them bigboatben from silver seas yachts sent you and they’ll take good care of you. When are your freshwater cooling system either flushed or removed and boiled out? If it’s been 5 years do that to before for running your new pumps. If you have to much back pressure in the raw water side of your freshwater cooling system you’re going end up with two new leaking pumps in short order.
Cheers,
Ben
Wow! Both circulating pumps failing? That seems highly strange. You’re leaking coolant from the seal on both? Not the gasket correct? If it’s not physically broke, I would just rebuild the seal/gasket. The part # should be 3582673. Gasket is 3818912. Double check my numbers, but that shouldnt be more than $75 an engine in parts. Hoses are the expensive thing.
  [Tiara Sovran] Low coolant temp Volvo Penta 600 Donaldjames 2 2,904 08-07-2023, 06:57 PM
Last Post: Donaldjames
  Performance Chip / Tuning Box for Volvo Penta D6-310 OffshoreTitan 0 1,459 05-19-2023, 12:39 PM
Last Post: OffshoreTitan
  [Tiara Sovran] Volvo primer bulb assembly Donaldjames 0 1,067 05-02-2023, 02:54 PM
  [Tiara Sovran] Volvo Penta D6 435D-A engines IPS 600 Albino58 0 1,789 06-02-2022, 07:32 AM
Last Post: Albino58
  1996 Volvo KAMD42P-A starting on its own!! M5finally 5 4,294 03-28-2022, 10:13 PM
Last Post: jmk
Volvo Penta Coolant Pumps00
