Main DC Circuit Breaker Part Recommendation
Can anyone recommend a main circuit breaker for all DC/12volt on my 1996 Pursuit 3100
This controls ALL 12 Volt in my boat (box located in engine room/upper left position)
the part number of the switch is as follows but I see no indication of AMPS for this switch.
ETA does not make this part anymore.
ETA
AC 115V - DC 28V
41-3-S14-LN2
thank you in advance.
Chesfisherman
According to this, 35 amp.
Thanks Cap.
The ETA info confusing around the web but found this pdf saying the LN2 series goes from 30-90 amps.
The wiring diagram for my 3100 says it is a 50 amp.  I think? (pic)
So I think I am after a 50 amp thermal breaker with the same form factor as the ETA.
agree/disagree?
Thank you!
not sure my attachments are ok...rookie
Thumbnail(s)
From the wiring diagram, I would agree with 50 amp.
    Purchased the following-
ETA 413-K14-LN2 50 amp for $58.
See attached order
FYI
Looking at the schematic I am a bit confused. It shows a 50 amp switch with a 60 amp fuse right in front of it. Is there a fuse inline somewhere prior to the switch?
Capt,
I think you may have a very good point here.  This circuit breaker is #1 important component on my boat.  It tripped during my last outing and would not reset.  Given my conversion to electric fuel pumps vs mechanical without 12 volt DC I was dead in the water.  By chance I had a thermal breaker for my Florida flats boat trolling motor aboard.  I had to remove breaker box...wire in trolling motor switch and was able to get main DC back so I could return to dock.
My schematics are on boat and will do a visual circuit trace to find this 50 and 60 amp components.
Will report back on correct amp for main breaker.
Question- What is your amperage for your main DC circuit breaker?  Your 3600 maybe higher than my 3100 but would be a good data point.
Sorry...your 41...Smile
I will have to look. My boat is 2 hours away so I may not get to it in the next week or so. I will let you know.
Capt-
You are correct...it was a 60 not a 50...very good catch from circuit diagram.
The old part did have “60” engraved on the button but was hard to see visually.
No need for checking of your boat.
Thank you!
Chesfisherman
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 578 07-15-2026, 08:06 AM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 680 03-28-2025, 09:44 PM
Last Post: Salty0ne
  Electric Breaker panel Jbuchsdvm 5 4,708 10-21-2024, 10:08 AM
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,519 09-28-2024, 09:01 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,569 08-18-2024, 07:22 PM
Main DC Circuit Breaker Part Recommendation00
