Help Please! 1994 Tiara 31 Open Alternator/Regulator Question
I have Crusader 454's. The port alternator appears to be a MANDO with a internal regulator. Originally it most likely was a Prestolite 8E with a external regulator. The problem is: the Alternator is putting out 17.2 plus volts even if I just start the engine and idle. Being that I need to change the oil and put the boat away for the winter (inside heated storage) I would like to somehow disconnect the alternator so it won't charge. I can't reach the back of it to see which wires etc; so I could follow some wire to disconnect. Using the Starboard engine/alternator as a guide, I notice that there is an Isolator on the bulk head. There's a red lead going from the isolator to the D red of the alternator.  Does anyone know if I can disconnect that wire and safely be able to start that engine without doing any damage?  Any information will be much appreciated.
Thank you.
Holts13 Confused
May seem obvious but I assume you verified that the alternator is in fact over-charging by using a digital volt meter on one of the battery posts? Wouldn't be the first time a gauge put out faulty information.
I am a little hesitant to offer too much advice here without seeing a diagram or knowing the configuration of the alternator. But yes if your problem alternator is connected to the isolator, removing and insulating (very important) the common lead (red wire from alternator) should prevent that alternator from outputting anything.
Safer option is probably to just remove the belt. Or if you are able to get to the small gage wires going into the regulator, disconnecting the excitation wire (usually purple) that connects to the key switch will prevent the alternator from generating any current. There is usually a barrel connector on this lead.
The other small gage wire is the battery sense wire. When troubleshooting check voltage here. A bad connection between this terminal and the battery bank will result in the alternator putting out full charge.
Good luck and remember to cap off/insulate any open wires to prevent a short. Also good practice to disconnect battery grounds prior to messing around with any wiring.
Thank you Admiral for your response. Yes, I did make sure I tested at the battery. It was actually putting out 64 volts. I am lucky that it doesn't appear I fried anything. I disconnected the red wire at the isolator and sure enough the alternator isn't charging anything. As it turns out I will be replacing both alternator's since the other looks just as old.
Again, thank you for your help. I'm sure I will need more as I continue bringing back this beautiful Tiara.
Holts13
  Tiara 40 Express 2003 - Removal of Cleat saywhen 1 299 10-27-2026, 02:43 PM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 481 08-18-2026, 02:11 PM
