What kind of dinghy davit for 3500 Express
I'm looking for suggestions on what type of davit to use on my 3500 Express with the 4' swimstep.
I want to keep the engine on the dinghy when it's out of the water.
Complicating matters, I am 76 years old and don't have the strength that I used to for dragging the boat onto the swim step. I currently use a soft bottom dinghy and a 6 hp outboard.
Does anyone have history/suggestions?
Thanks.
Here is an old thread on the setup we had on our 39 Sovran... The block and tackle made retrieving the dinghy a lot easier. You could probably find a portable electric winch in place of the block and tackle to further automate the process...
I am in the process of installing the Hurley H3O setup with power winch. Same platform as yours...
August, what led you to choose this option?
(01-28-2021, 03:09 PM)Norm Wrote: August, what led you to choose this option?
I have had smaller ribs, most recently a Mercury 280 Dynamic with a Mercury 9.9.   For that I was using the Nautley Dingy Ramp HD's.    Worked great but still a manual load process which wasn't an issue since the boat and motor probably weighed around 2020 lbs or so.
New RIB is a 11' Inmar with a 25HP Suzuki- Full console boat, so over double the weight of the previous RIB.   The H3O plus handles up to 750 lbs.  It comes with a winch to load and unload.   They make a standard H3O that handles less weight.  This seemed like the best option compared to other major projects like Freedom lifts that can cost north of $25k.   Although I bought my H3O setup slightly used, the new set ups are around $4k or so.   There are a few models...
So in short, if you are looking at manual pull on Davits I would highly suggest the Nautley Dingy Ramp HD's.   If you want something more automated and are going with a larger RIB, I would say Hurley H3O.
I just re-read your post. Sounds like you have a smaller inflatable. If that is what you are planning to keep, you should be fine with normal manual load davits from Nautley.
Thank you for the information August. Now I have two good choices.
On a previous bridge boat I had the original Hurley Davit and a pretty heavy RIB with a 15hp outboard. I used a block and tackle (purchased from Hurley Marine) [Only registered and activated users can see links Click here to register] that I attached to the bridge that helped me load the dink. The H3O is really nice if you have the room although I like the Nautley DinghyRamp HD+. If you have questions about the block & tackle let me know. I think I still have mine if you are interested.
(01-28-2021, 11:34 AM)Norm Wrote: I'm looking for suggestions on what type of davit to use on my 3500 Express with the 4' swimstep.
Thanks.
I am in the process of buying a Hurley Marine System.  I have a 9 foot dinghy, hard botton, with a 9.9 hp.  My swimplatorm is 24" and 9 feet wide hurley marine was very helpful when I called them.  There are you tube videos on showing people how to pull it on.  Seems easy, but I am not sure of the strength needed to pull it up, mine is 160 lbs. with engine.
I'm in a 4000 Express and just getting into the dinghy game. I bought a Zodiac Wave Areo (10'2, PVC, air floor) from Defender.com and a Torqueedo 1103 electric 3HP. The dinghy weighs in at about 60lbs so I opted for the Weaver Snap Davit (here: [Only registered and activated users can see links Click here to register])
The advantage for me is the snaps keep the dinghy in place while loading & unloading and it's low cost and not intrusive. I don't need it with an electric motor but they offer a swivel mount for your transom that keeps the motor straight when you tilt the boat up.
Good luck and let us know what you decided!
  2001 3500 open, diesel exhaust flanges? North Star 4 1,106 02-24-2026, 08:55 AM
Last Post: North Star
  2001 5200 Express knot@work 0 1,645 12-02-2025, 09:28 AM
Last Post: knot@work
  1996 Express 3500 TomReaginCarney 2 800 06-10-2025, 08:04 AM
Last Post: TomReaginCarney
  3500 Express Factory Option Trunk Dinghy Outboard Mount Picture JMGCINCY2023 0 611 05-18-2025, 07:50 PM
  2000 Express 35 Convert Forward Bunk to Center Queen JMGCINCY2023 2 2,233 05-10-2025, 07:33 PM
What kind of dinghy davit for 3500 Express00
