Tiara Open 1990 Vacuflush
My vacuflush is tripping the breaker when I try to use it. First problem I've had with it.
Check for blockage of one of the duckbills before or after the pump.
Thanks for the tip. I'll check it out.
Do you hear the Vaccu pump running at all? Or does it not even try to run?
It doesn't even try. As soon as I touch the pedal the breaker trips and it also trips without touching the pedal.
You have an electrical short. If you do not know electronics, you can try just replacing the pump.
That was my initial thought. I will verify that the ground side is good then try jumping the positive side of pump connection to see if it runs and go from there. I replaced both engines this past spring and it's to bad it wasn't failing when I had plenty of room to work the problem.
I would not recommend jumping the motor as a first step. All you are doing is bypassing the pressure switch, but those never short to ground anyway since that is all but impossible the way they are installed. Normally you’d check to see what resistance the motor coil has and check if it is shorted, and take it from there.
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 664 05-27-2025, 04:49 PM
  1990 Tiara VDO Tachometer gybe24 3 3,569 06-09-2022, 08:55 AM
Last Post: gybe24
  [Tiara Convertible] Tiara 1990 36 Convertible Windlass Installation Tiara 3600 2 2,679 05-09-2022, 02:22 PM
Last Post: Misdirection
  1990 Tiara 2700 Open. HELP! ToroDude1 3 4,643 10-20-2021, 05:34 PM
  [Tiara Open] 1990 31 gybe24 2 2,422 07-15-2021, 09:00 AM
Last Post: gybe24
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
