Threads: 7
Does anyone know if the 3100 Open is greater then or less then 5 tons as described by USCG Vessel Documentation ?
Threads: 22
5
Home Port: Stuart, FL
My 31 Open was documented. The catalog states an approximate dry weight of 10,500 lbs. Net tonnage is a measure of a vessel's volume. It should not be confused with the vessel's weight, which may also be expressed in tons. Most vessels more than 25 feet in length will measure five net tons or more. Capt. George
Threads: 16
Home Port: Red Bank, New Jersey
Vessel Info: 1996 Tiara 29 open, Twin Crusaders 454XLI
I would think a 31 is greater than because my 29 is 10,500 and is documented with the Coast Guard.
Threads: 7
The Marine title company I used for the transaction did the USCG documented vessel application and calculated the gross and net based on the USCG formula. Based on that formula the 3100 came in at 14 gross and 11 net tons.
Threads: 0
Home Port: Chesapeake Bay
Vessel Info: 2001 38 ft Tiara Open
Twin Cummins 440
Can anyone help me with the gross tonnage for a 2001 38ft Open?
Threads: 14
11
Home Port: Kings Park, NY
The gross tonnage for my 2003 38 Open on my documentation papers is: 25 GRT and the net tonnage is: 20 NRT.. Hope this helps
