Slow rolling start
Was wondering how you guys start your boat, do you turn on generator, then flip power to generator, then start, or do you leave shore power plugged in and start your boat with the power cord plugged in to shore power?? Which way do you think your getting more starting power?? Have cummins qsm11 engines, my port engine slow roll starts and I must use my battery parallel, it does start every time not just as fast as my starboard side, I have all new batteries???? Need a little help or advice, thank you!!!
To answer your first question, it’s start generator, transfer power, disconnect shore power, start engines. But I can’t imagine how any combination of that is affecting your cranking. I’d start by examining the cranking amps of your engine batteries. Just because they’re new doesn’t mean they’re correct. You should not need to use the crossover to start your batteries. Do your batteries have the correct cold cranking amps? Are they properly connected? Is everything grounded correctly?
If all that checks out, I’d start investigating your starter.
Did it always do that or started with the new batteries?
I always start the generator first. Mainly because if the engines are running I can't hear it start. I unhook the shore power while the engines are warming up.
We had the same issue where especially the stbd motor on our previous '03 Cat powered 42 would crank slow. I upgraded the starters to a newer gear reduction style and it fixed the issue.
Max
THANK YOU MAX.....
  SLOW ROLLING START honest mark 4 3,002 10-11-2023, 01:59 PM
Last Post: m.t.bentz
  2003 - 42 Open will QSM 11's - 660hp, slow starting crank fps42 7 11,140 02-25-2020, 07:47 PM
Last Post: Tiara Mike
