Where is Water Coming In?
Not a huge problem -- but there seems to be a consistent amount of water in my mid bildge and forward bilge (boat is a 29 Coronet).  The bit of water in the forward bilge is often foul smelling especially when the boat is sitting a while and the cabin is so small that it is noticeable.
My bilge pumps never run on there own (i.e., there is never enough water to trigger the float switch).  I usually switch them on manually for a bit after each run of the boat.
Any thoughts on where to look as to where water is coming in? Or is this just an inevitable that I should live with?
Thanks,
The only things I can come up with
Shower sump not pumping
Air conditioning condensate drain blockage
Hot water tank leak
Thru hull weeping
I hope you find something
Check the drain in the anchor locker.
(08-05-2023, 08:22 PM)Sans Peur Wrote: Check the drain in the anchor locker.
Thanks for the suggestions.
I don't have an AC or a shower in this boat.
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,686 05-12-2026, 10:18 AM
  Water alarm in the diesel filters maxcav 0 519 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 631 11-21-2025, 05:53 PM
Last Post: lenoah
  [Tiara Open] Water under Quartz flooring in head benmaser 0 727 06-16-2025, 02:24 PM
Last Post: benmaser
