Crusader 502XLI ECM Harness 10 Amp Circuit Breaker tripping
New here and looking for some help. 1998 Tiara 3500 Express with Crusader 502 XLI's. After running for around 25-30 minutes Strbd motor will shut down while running regardless of RPM. (in most instances 2900-3400RPM). Water temps and oil pressure all indicate normal. Discovered 10 amp ECM harness circuit breaker on engine had tripped. Reset breaker and all works as it should. Once back up to normal operating temps breaker continues to trip after 25-minutes (or so) running. Replaced ECM harness circuit breaker and the problem persists. Replaced ignition control module and still experiencing the same problem. Not sure where to go from here. In order to get the boat back in the dock I have to reset the breaker so I have the use of both motors, but that makes it so it can't be troubleshot. Any advice would be greatly appreciated. I believe it's heat related whatever may be causing the breaker to trip, but there's nothing indicating any kind of overheat issue. Is it possible the ignition relay could cause this? Thanks for any and all help!
Is it the 10 amp fuel pump circuit breaker that is tripping?  I am having the same problem on my 1996 Tiara 3100 open with Crusader 454 XLi's.  I tested the fuel pump and it works fine.  The Fuel pump is supposed to draw less than 4.5 amps but if there is excessive resistance it could cause the amperage draw to exceed 10 amps and trip the breaker.  My next step is to test amperage draw of the fuel pump.  Anyone else have this problem?
MT Gates
1996 Tiara 3100 Open
Crusader 454 XLi's
1600 hours
MT Gates
1996 Tiara 31 Open
Twin Crusader 454 XLi TBI
The label on the breakers was in the wrong place. After chasing the wires back they were actually labeled "fuel pump". The fuel pump would begin to overheat after 25-30 minutes under a load. Replaced the fuel pump and all has been fine since.
(04-27-2025, 10:13 AM)Mtgates44 Wrote: Is it the 10 amp fuel pump circuit breaker that is tripping?  I am having the same problem on my 1996 Tiara 3100 open with Crusader 454 XLi's.  I tested the fuel pump and it works fine.  The Fuel pump is supposed to draw less than 4.5 amps but if there is excessive resistance it could cause the amperage draw to exceed 10 amps and trip the breaker.  My next step is to test amperage draw of the fuel pump.  Anyone else have this problem?
MT Gates
Crusader 454 XLi's
1600 hours
  [Tiara Open] Crusader MP7.4L Air Inlet Tube mikezacharias 6 3,072 04-28-2026, 06:17 PM
Last Post: bob4144@icloud.com
  [Tiara Open] Flushing coolant and replace crusader 454xl Mydiamond 0 976 09-20-2025, 06:41 AM
  2005 3200 Open w/ Crusader 8.1 - Fuel line size? tyrentz 1 1,149 12-02-2024, 09:55 AM
Last Post: Hooper
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 5 2,486 08-19-2024, 07:22 PM
  2005 Crusader 8.1 Exhaust Elbows Matta0413 1 1,601 10-05-2023, 04:50 PM
Yesterday 05:08 PM
