Threads: 17
Home Port: Lake Ontario
Vessel Info: 2001
31 Open
8.1
Is the Charles C-Charger a battery charger or is it as described on their manual a"Marine Electronic Alternator Regulator". I thought a charger and a regulator are not the same.
Threads: 4
12
Home Port: Newport
A charger and regulator are not the same, but Charles very confusingly labeled their alternator regulators 'C-Charger'. They also labeled their battery chargers as 'C-Charger' to add to the confusion. Bottom line is it could be either.
Threads: 17
Vessel Info: 2001
31 Open
8.1
It would seem that I have the regulator, however on the AC panel there is a switch "Battery Charger" which I can not locate. Where could it be hiding?
Threads: 17
Vessel Info: 2001
31 Open
8.1
2001 3100 open 8.1 engines.
Threads: 17
Vessel Info: 2001
31 Open
8.1
The charger is on the inside bulkhead behind the panel behind the lounge seat. It's dead, replaced it with a 15 volt 2 bank seems to be working now.
