Hatch Trim - Skyscreen replacement
Hey all Tiara Fans!
Need some advise or to locate proper resources. Setting: 98 Tiara 31 Open
Am replacing the existing Front hatch screen set-up with an OceanAire Sky Shade (screen & Shade. The existing hatch trim was cracked and discolored, so it ha been removed.
Here's the questions, the skyscreen is a bit larger on all sides that the hatch, so I am in need of a "L: shaped trim piece to provide a clean finish. It's about an inch to an inch and a half.
The trim options with Oceanaire are straight trim or a filler that essentially "lifts" the screen over existing hatch trim. Neither of these works.
Any ideas??
Thanks all - great forum!
I had a client retrofit the ocean airs into a 35 Open. He used Teak trim to match the interior. It looked great when he was finished, but expensive. He had a carpenter do the wood work.
The other option is to contact a local plastics company. They should have all types sizes and styles of plastic trim. They may even be able to custom make something for you.
Good Luck!
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 391 08-21-2026, 02:33 PM
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 487 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 455 07-25-2026, 09:15 AM
Last Post: roboh20
  [Tiara Open] Trim Tab Hydraulic System Bob's Boat 0 439 07-19-2026, 02:41 PM
Last Post: Bob's Boat
  Freezer Replacement for 40' Tiara Reprise1 4 1,922 06-09-2026, 02:28 PM
Last Post: fuzzy
