J Lounge Removal on 32 Open
Trying to remove the j lounge from the upper cockpit area of my 2005 32open. I removed the 6 lags I can see from inside the storage area but to no avail the lounge is held down tight. Appears to be secured down with some sealant?? Has anyone removed the seat before any help appreciated.
        thanks
I haven't removed anything that sizable from my 98 31 Open, but I've worked around a couple of other items and found most positioned with 5200 in addition to fixed fasteners.  I've had good success with a heat gun warming the materials and using a scraper to get in the tight places to break the sealant bonds.
Good luck.
A length of piano wire around two dowels can be used as a saw along with lots of WD40 to cut through a sealant. Wooden wedges for pry's also help. Capt. George
Thanks for the help. Will try the piano wire.
  38 open bathroom recessed light bulb twilson0929 3 313 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 293 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 634 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,260 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 694 05-12-2026, 10:18 AM
J Lounge Removal on 32 Open00
